I have tried to follow instructions from the manual by adjust the trays but could not help.what can be the cause?
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
SOURCE: Need instructions for replacing upper output tray assembly
Go to this link and follow the manual.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01527492/c01527492.pdf?jumpid=reg_R1002_USEN
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
