SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
SOURCE: My lawn mower will not stay started
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jim
SOURCE: Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
SOURCE: Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
SOURCE: CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
