KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
A
Anonymous Posted on Apr 22, 2014
Beater is hitting bowl - KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
John Fink
Level 2:
Champion:
  • KitchenAid Expert 202 Answers
  • Posted on Oct 02, 2016
John Fink
KitchenAid Expert
Level 2:
Champion:
Answers
202
Questions
0
Helped
113140
Points
273
You can find the User's Manual (which shows how to adjust beater-bowl clearance) for your model at:
https://www.kitchenaid.com/customer-service/manuals/
5 Related Answers
oscarn
Oscar Netto
  • 110 Answers
  • Posted on Dec 21, 2007
SOURCE: beaters hitting the bottom of the bowl, and can't tighten the screw at the base of the arm any tighter. what to do?
Try lowering the bowl by removing the pad below the base of the bowl.
Anonymous
  • Posted on Sep 05, 2008
SOURCE: Kitchen aide mixer
i noticed my kitchen aide mixer is sounding like it is bogging down slightly while it is running it is not used very much and bought christmas 2007 others who own them have said theirs doesnt do that should i be concerned
Anonymous
  • 145 Answers
  • Posted on Jul 08, 2009
SOURCE: Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Anonymous
  • 4 Answers
  • Posted on Jan 03, 2010
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Testimonial: "Thank you for your post. I will check out the suggestionsl"
Anonymous
  • 130 Answers
  • Posted on Apr 06, 2010
SOURCE: cant adjust flat beater so it wont hit the
all tilt head mixers pivot on a pin which goes thru the head and the base. This pin is held in in place with a screw which you can access from underneath the base. Try tightening the screw and see if that tightens up the the loose head.
If the looseness is in the gear head then the five screws which hold the top and bottom halves of the gearcase together. Remove the chrome ring by gently prying it off, then drive the pin out which goes thru the planetary housing and the shaft and drop the planetary housing to access the 5 (item 19) screws.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
Kitchen aid model kg25. vibrates and beater hits bottom of bowl
Your worm gear is no longer seated and that is more than likely because the housing cover is probably the old style plastic and it has cracked which allows the worm gear to jump up during operation and turn out of sync. The worm gear turns the drive gear that works the planetary gears which in turn drives the beater. If the worm gear is not turning true then of course it is pushing the planetary out of true as it turns, which causes the beater to slam the sides of the bowl. The question is this...does the beater hit the bowl in the same place on the bowl every time? Or does the beater hit the bowl in different places every time? If it hits the same place then it is probably just a planetary gear of which there are four gears involved and it could be any one of them. It it hits a different place every time it is most likely the worm gear and cover. In either case parts will cost between 30 and 50 dollars. and it takes about an hour to fix.
Dec 30, 2014 • Food Mixers
1helpful
Beater hits side of bowl
What part number did you order for the beater and what is the model number for the mixer? Also is the mixer brand new, or did you get it used and it just started happening?
1helpful
2answers
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Beater hits bowl beater height adjustment screw does not fix problem
Is this a new beater that you just bought? Or is it the same beater you have had? When you adjust the screw, which way are you turning the screw, how much is it hitting the bowl?
If the beater is too close to the bowl the adjustment screw should be turned in. If the threads on the screw are loose the screw needs to be replaced.
Page 17 and 21 both show how to adjust the head of the mixer so the beater his the bowl correctly. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Please let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
[email protected]
800-339-9297
I have a KitchenAid mixer KM25GOX NSF, Model serial number WT2333793. I purchased on eBay & it is in great condition, but the flat beater hits the bottom of the bowl & the adjustment screw doesnt...
1. Unplug stand mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl
when in lifted position by turning screw
(A) Counterclockwise to lower the bowl.
5. Just a slight turn 90 degrees in either direction.
Place bowl lift handle in up position to check clearance.
6. Repeat Steps 4 and 5 if necessary.
I hope I helped you.
7helpful
The paddle on my mixer runs too low and hits the bottom of the bowl. any ideas?
Hi ERIN. This should be pretty easy to do by yourself. The instructions for adjusting your beater to bowl clearance is in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case K$45SSW and select the file listed for your model that appears under Owners Manuals (2): K45SSWH-0.pdf (2730.37 KB) and save that file to your PC. Turn to Page 13 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
I hope this helps! – Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Mixing blade gets hung up at same spot on each turn
Hi SUSAN. From the symptoms you describe, it sounds like your mixer has a ‘Bowl to Beater Clearance’ issue. That should be pretty simple to fix. But even before we go there, check to make sure your mixing bowl is seating properly in the Bowl Support yolk and ‘snaps’ into place against the Bowl Spring Latch. My wife’s had that happen to her a few times. She thought the bowl was seated tightly, but it wasn’t and she experienced the same problem as you.
If your bowl is seating properly, the next thing to look at is your Beater to Bowl Clearance. The instructions are located in your Owners Instructions manual that came with your mixer. If your lacking one, you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KT2651 )and select the last file listed that appear under Owners Manuals (44): KT2651XWW3.pdf (2974.69 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 10 and you will find the instructions for adjusting the mixer head height.
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
2helpful
2answers
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
Dec 18, 2009 • Food Mixers
1helpful
I need to lift the head a little. the wire whip
Hi LEDAVETORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
• Turn scre3e30899.jpgw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
