HP OfficeJet J4580 All-In-One Laser Printer Logo
A
Anonymous Posted on Apr 22, 2014
Dell 1130n manual - HP OfficeJet J4580 All-In-One Laser Printer
Scanning with Dell 1130
Which Dell 113x do you have? There are the Dell 1130 and Dell 1130n Monochrome laser printers that do not have a scanning unit. See https://www.dell.com/support/home/us/en/04/product-support/product/dell-1130/docs . If you have these, you can't scan. If you have an all-in-one, perhaps the Dell 1135n multi-function laser printer, https://www.dell.com/support/home/us/en/04/product-support/product/dell-1135n/docs , see below. Dell also lists a B1163 multi-function printer. See Dell support for the printer list of US printers: https://www.dell.com/support/home/us/en/04/products/electronics_accessories/electronics_accessories_printers?app=products&~ck=mn .
In general, for multi-function printers, the unit must be in a ready to print state. (Out of ink messages will stop the unit from scanning.) Next the full software package should be installed before connecting the USB cable, if that is used. If the OS finds the drivers, you may only get the printer drivers.
Next two-way communication must be allowed. For a USB cable, don't use a cable longer than 6' and replace it if there is a communication error. For a network connection, make sure that the firewall is set up to allow the communication. Finally, try to launch a scan from the computer, using the software that is part of the full package. You will need to have a scanning monitor launched during boot to look for button presses on the scanner. This monitoring software requires some setup before it correctly responds to the button presses. For Windows, this is the Dell Scan and Fax Manager (on the 1135n). You need to enter the Properties section for the printer. Then go to the Set Scan Button tab and use the Available Applications list to move the desired applications to the Front Panel Scan Destination. You should also set the file type here. In the Scan Property section, set the default destination for scanned images, the standard resolution, and other items. Also make sure to set the type of connect in the Change Port tab. For the documentation on the scanner for the 1135n, see page 47 on at https://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers_mono_laser/dell-1135n_user%27s%20guide_en-us.pdf .
I hope this helps. Please add a comment if you have a different all-in-one printer.
Where can I download an owner's manual?
Inspiron 6000 Service Manual - Product Support ' Dell US
www.dell.com/support/home/us/en/19/.../inspiron-6000/manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
DELL 6000 OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
4answers
Service manual for dell 2007fpb
Alexander Alenin wants more answers to this question
why not start you own post. not hyjack others. from 2015
I am having problems with printing. The printer is already connected to the computer, but it will not print.
1.first check if the printer is detected by the computer in devices and printers,
2.go to services.msc ,.. stop and start the print spooler service and print and see
3. U can try the troubleshoot step under devices and printer for ur desired printer. and it should work.
Incomplete session by time out
Hi Michael,
What are the PCL Drivers that you are using for the printer. Normally, Changing/installing different PCL drivers fix the issue.
For Ex, If you are using PCL6 drivers, try PCL5e
Regards,Suhail
1helpful
Paper jam for dell 1130 laser printer
Ive got a Dell 1130n that was jamming once it came out towards the top. if you take the top off (2 screws in front and 2 screws in the back) and the rollers right there at the back (once you get the top off) take that long "roller bar" and the springs that push up on that bar just slightly stretch them out and clean the rubber wheels with soap and water (allow to dry) and put everything back together. Also the wheels in the back could be cleaned too. If you open the rear cover there is another "roller bar", there are grey clips on each side that if you pull down the click into place, just unsnap the "roller bar" and clean these wheels as well. It has worked great for me so far.
What does a red flashing light mean on a dell 1130n printer
may is there an error with the papers or the ink cartouche
2answers
Getting a manual
Use this link download varies manual concerning to system
http://searchapj.dell.com/results.aspx?s=dhs&c=in&l=en&cs=indhs1&k=Dell+530+Inspiron+manual&cat=all
the above will give below information on the site
Appendix: Dell Inspiron 530 Owner's Manual ... Appendix Dell Inspiron 530 Owner's Manual Specifications ...Cleaning Your Computer Dell Technical Support Policy (U... Product name: Dell Inspiron 530 Model number: ... Setting Up and Using Your Computer: Dell Inspiron 530 Owner's Manua... ...Using Your Computer Dell Inspiron 530 Owner's Manual Front View of the Computer...your computer when you access the Dell Support website or call technical...specifications indicated in this Owner's Manual reflects the maximum ambient operating... Glossary: Dell Inspiron 530 Owner's Manual ... Glossary Dell Inspiron 530 Owner's Manual Terms in this Glossary...code located on a sticker on your Dell computer. Use the Express Service Code when contacting Dell for assistance. Express Service...
k24674
Grand Canyon Tech
Grand Canyon Tech
