Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
A
Anonymous Posted on Dec 22, 2017
I have a Dyson DC07. The roller wasn't spinning so I cleaned the brush of hair and fibers. That SEEMED to do the trick. But while vacuuming I noticed again that the roller brush was not spinning AGAIN. The belt by the roller brush is intact. The filter is clean, and no blockages anywhere.
Thatvacguy.com
Level 3:
  • Dyson Master 1,619 Answers
  • Posted on Dec 23, 2017
Thatvacguy.com
Dyson Master
Level 3:
Answers
1619
Questions
0
Helped
604527
Points
3345
You may need new belts. Belts lose elasticity from being stretched. The clutch must be removed and disassembled to change the belts. It's easier to replace the clutch. The belts will be tight and It's difficult without a special tool. While you have the brushroll out pull the shaft out of the center and clean hair and debris from it or replace brushroll if worn or frayed.
5 Related Answers
Anonymous
  • 372 Answers
  • Posted on May 18, 2008
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Anonymous
  • Posted on Jun 10, 2009
SOURCE: My Dyson DC07 stops working after a few minutes.
Have you tried calling Dyson? I had a problem with my Animal, and their tech department talked me though the fix. Worth trying them first.
Anonymous
  • 701 Answers
  • Posted on Nov 19, 2009
SOURCE: My dyson dc07 brush bar seems to be only spinning
The belt is stretch and so it is slipping on the motor shaft. You need to change the belt. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Anonymous
  • 458 Answers
  • Posted on Feb 28, 2010
SOURCE: I have a dyson dc07 upright which no longer picks
need replaced Clutch Assy and Brushbar
Clutch Assy part no:900252-04
Brushbar Assy part no:904174-01
try cleaning all Hose
Anonymous
  • Posted on Mar 16, 2010
SOURCE: Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
Dc59 motorhead carbon fiber brush not moving.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
2answers
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
https://www.thinkcrucial.com/search?type=product&q=dc07
Ava B.
Dyson DC18 All-floor Vacuum bristles won't turn
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
My dyson dc07 brush is not spinning
Ava B.
2answers
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
1helpful
2answers
Brush bar is scratching hardwood floors. It seems too low!
There are a number of reasons why your brush roller is not working properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
Ava B.
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
15helpful
2answers
Belt not turning
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
