My Kenmore 23812 top load washer will drain but it doesn't spin while its draining, then it will spin during the rinse cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Hi, The washer is designed to drain the water before it spins. Does it spin the clothes dry in the final spin cycle?
Vic
