The battery flshing a red light
SOURCE: red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
SOURCE: Flshing red light
When someone say that his/her Xbox is having 3 red lights
problem, It means it needs to be repaired. If you are using Cooler than
it is not a cure but a prevention. You could have used cooler before
acutally having the problem just to prevent your Xbox. But now you will
have to either get it repaired from Microsoft (in case your Xbox's
warranty is not expired, but one thing to note is that you will have to
wait for at least 3-4 weeks to get back your Xbox) or you can Fix your
Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
SOURCE: My playstation 3 switched off during an online
this is whats known as the yellow light of death (ironic i know since the light is red). your unit will need to be professionally repaired in order to work properly. check with sony to see if your unit is under warranty at this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_cEAAC34B3-EB87-3418-0E31-7DFCB50B79FA_k5CC13D12-5188-1981-F23C-95AE6A57CEE7
if your unit is no longer under warranty, go to www.wiredextreme.com. we'd be glad to fix this problem for you. all of our repairs come with a 90 day warranty that covers the whole console, not just what we fix. we also offer extended warranties for up to 4 years at an additional cost. you can contact us at 214-222-5788 or [email protected]
Testimonial: "quick and accurrate - just a shame in the US to get the fix done. Still, useful info."
SOURCE: JUST PUT ON A SLIP ON EXT MADE BUY D&D. MY RED
I would take the pipe off, put on the old pipe, see if that is the problem before blaming it. They usually have to get the computer reset for a difference in fuel flow, or,,, or, just run them and let them reset themselves. I know my bike does both. They have pipes from the factory with chips, and they have pipes without the chips. So, You will have to do some homework. I don't know what the pipe would have to do with the FI? Unless it is reading the O2 levels too high or low or something. If you ave a number for D&D, I would call them. They would know. Hope this helps.
