Good Morning i have a xerox 3100mfp
its sowing me a printer error
FUSER tEMP
Maybe try this, it woks on Sagem that also produces xerox mfp...
Follow the keystrokes set out below, do not worry about what is on the display unless stated to check. All letters referred to are for the keys on the alpha key pad to the right of the control panel, under the plastic flap.
1st option: Press down arrow, *, #, ok, 1, ok, stop (red button),
Press down arrow, #, T.
The machine returns to the error code. Switch the machine off for 10 seconds, switch
back on. If successful the machine will warm up and come ready.
Press down arrow, *, #, 0 (ZERO), ok, stop.
2nd option
Press down arrow, *, #, ok, 1, ok, stop.
Press down arrow, #, look on the display, press up arrow until "T>>PRINTER" is
displayed. Press ok. The machine returns to the error code. Switch the machine off for 10
seconds, switch it back on. If successful the machine will warm up and come ready.
Press down arrow, *, #, ok, 0 (ZERO), ok, stop.
If this is a recurring problem the firmware on the board may need to be upgraded, or there
is a physical fault with the fuser unit. Low voltage / power surges in the supply power to
the machine may also play a part in the occurrence of the error.
The firmware needs to be version 1.10.
To check the firmware version do the following:
Press down arrow, *, W
Firmware version is displayed. Press stop to clear screen.
5401:
Press *
The trace lists will be printed, firmware version is after PRT, as in example below.
In this example, the printer firmware is: PRT V 1.5
It is older than V 1.10 and the printer firmware need to be upgraded.njk
