Log into the web page log in as an admin you can switch it in there the defaults are usally Admin Admin or admin00 if you can log in as an admin you may have to do a factory reset
PDF
Copying or Moving a Subscription . ... Password: guest. For greater security, we recommend changing the default passwords immediately after ... Note: To prevent the browser from freezing, do not use the keyboard shortcut. Ctrl+N to open a ...
Nov. 25, 2014 - From our copier service company: This reset is used for two purposes: 1) reset any data that may be hung up in the hard drive. 2) reset an error ...
BUT You probably need a service call.
are you asking for the password the default passwords are either Admin or admin00 that is for the web page on the machine its usally Admin or the speed of the mACHINE PLUSE TWO zeros
try Admin on both username and password ( A caps).
Also try 3000 on both or 6000 on both. try to select the system menu button and type the username and password there.
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
