Yamakawa DVD-275 DVD Player Logo
A
Anonymous Posted on Apr 22, 2014
Can't change region code
Hi; there's no way of setting the region code, even though it;s supposed to be region free. Please help.
2answers
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
2answers
Hi my dell inspiron 530 computer recently can't play disc ,so like most people i checked for solutions for this problem ,non of them worked which got me furious until i found out that my Region fo
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
2answers
I have a Panasonic DMP-BD80 BluRay player purchased in Australia. It cannot read BluRay discs purchased in China. Please help me solve the problem/unlock the region code. Thanks & Regards, Glenn
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
2answers
Region 1 DVDs will not play on my recently purchased panasonic blu ray. is there any input code to allow play
Regards, Jay__okp9
How can i change regional code on panasonic sc-bt207
Regards, Jay__yhg6
1helpful
2answers
Need region free code for Panasonic DMR-ES46V DVD/ Vcr Recorder
Regards, Jay__jn89
1helpful
2answers
Change DVD Region Code
Regards, Jay__okj4
2answers
Laptop - region codes for dvd
theres a few things you can do here.If you have your instalation disk you can perform repair even though theres nothing to repair your cd will be set to 0.the only time you have a region code set is if some one has set it previously.Dont suppose you wanna do that .You could check your model of cd/dvd player in system information then get the firmware of the net.just type in search engine model of drive followed by firmware.by installing firmware it will auto set drive to 0 (any region)...
You can also download a program(free)called "any dvd" this program enable you to play any region dvds.
Top Yamakawa Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Yamakawa Televison and Video Expert? Answer questions, earn points and help others
