Xelio P900A-BK 9" 8 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen, 800x480 Logo
A
Anonymous Posted on Apr 22, 2014
Won't boot up just says booting forever - Xelio P900A-BK 9" 8 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen, 800x480
Won't boot past tv face
Won't boot past tv face - Fixya
www.fixya.com/support/t26041897-boot_past_tv_face
34 mins ago - Won't boot past tv face - Kurio 7S Tablet question. ... How do I show a video from face book it just boots me off. Dec 20, 2014 ' Apple iPad 2.
My kurio 7 tablet is stuck in the kurio loading page. What can ...
www.askmefast.com > Computers & Internet > Google > Tablet
Kurio 7 tablet how to fix when the smiley face screen stays on the screen .... Kurio 4s wont pass start up ... Kurio 7 won t go pass the smiley box ..... My kurio 7 has been dead for awhile and is stuck on the screen with the little tv what do i do?
[PDF]INSTRUCTION MANUAL - Kurio
www.kurioworld.com/k/us/parents/pdf/Kurio7_Manual_US.pdf
The Ultimate Androidâ„¢ Tablet for Familiesâ„¢ .... Connect Kurio to TV screen. .....Note: The reactivity of the touch screen can vary from one person to another, which is linked to the nature ... To exit the Android interface and go back to Kurio interface, press . .... When the icon is like this , the user won't be able to delete or add.
Getting started - Kurio 7 - Kurio Tablets
www.kurioworld.com/k/us/parents/support/7/gettingstarted
M729b won't boot
i cant ulock tablet forgot password please can you help
My zeepad won't boot up
I'm having the same problem I've tried everything and nothing's working please help
When entering a website it boots me back to main screen and won't let me search the web
Your probably using Google and because of an upgrade you can't use google anymore. Try Bing as your search engine and you should be fine.
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
My hp tx2120 us was upgraded to windows 7 and has been working great for several months. Now it won't boot up. The lights on the volume control light up, the fan turns on, but the screen remains black....
You may have finally run into the dreaded "defective GPU" issue, that plagued HP and other manufacturers. Thousands of defective Nvidia chip sets were used in the manufacture of these laptops and if you got one of these, it would last about a year, then fail, in the just the way you describe. If you were out of warranty, HP took the low road and refused to fix them, unless you ponied up $450. Then they replaced the defective motherboards with a new one, with exactly the same component.
If you have one of these, you will better of buying a new machine. I'd avoid HP though.
4helpful
2answers
Laptop will not go in BIOS or boot up
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Top Xelio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Xelio Tablet and eReader Expert? Answer questions, earn points and help others
