Hello, I am looking icc profile file for screen hyundai X93SD. thank you
SOURCE: What is ICC profile?
ICC profile can be used in any ICC aware application or platform, and describes usable information to convert into a color space which defined by ICC (International Color Consortium). DiMAGE A1 has a function to embed ICC file to the captured image. Please make use of the function "Embedded Adobe RGB" to use correct color information on application software which corresponds to color management system.
SOURCE: Error message
The ICC profiles on your printer are corrupted.. Click here to download new profiles.
SOURCE: Could not read the ICC profile. Saving image canceled.
ICC = International Color Consortium.
The ICC's should be installed in the default printer directory.
Also, you may want to check the printer profile. In printer properties under the "color management" tab check to see if automatic or manual is highlighted. If manual is highlighted, be sure the print profile matches that of the paper you are using. You can select any of the included profiles as the default or add your own from a third source. Such third-source profiles are most often specified by your software provider
SOURCE: Epson Stylus Photo R265 icc problems
Great Answer Malco, I hope with this credit crunch you will lose your job in Epsom, the correct answer should be how come Epsom rip off customers with inks
The correct answer should be there are good and bad CIS suppliers as a rule of thumb anything from China is pretty crappy, but check out which ones are reported as good, I use signal inks, but there are far better inks out there, just research on the net.
Also matching the screen to the print out put is mostly the biggest problem, is all about tweaking the settings.
Regards
SOURCE: Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Nolasco.
