My T276 Alarm Clock switched over auto on the old daylight saving time but was too early is there a fix to change over to the new daylight saving time. Thank You
I have a cube-shaped, silver Timex alarm clock that plays CD's. The fact that it springs forward and falls back on the WRONG schedule (because of the changes in DST) is a big problem, evidenced by this morning...my clock "fell back" and it thought it was 6:30am instead of 7:30...I was awakened 1 hour LATE (i.e., at 7:30 real time, instead of 6:30). The manual says "if you live in area that does not use daylight savings time, you must reset the clock when automatic adjustments occur." It doesn't let you change time zones. I'm just going to have to buy a new clock, when this one is perfectly fine otherwise. Frustrating.
Call 18006954820 they will walk you through
I called the suggested 800# for Timex and was told that there was no fix to change to the new daylight saving time.
What about changing the time zone?
Change to Hawaiian time they do not follow DST. Then just manually set it each spring and fall for spring forward and fall back.
I had the same problem so I changed the time zone. Is there an upgrade or something to fix the problem for the future?
I was so delighted several years ago when I purchased a T276 clock radio with alarm and automatic time adjustment at the beginning and end of Dayight Savings Time. But then Congress went ahead and changed the dates of Daylight Savings Time and now the switch needs to be done manually. I relied on the automatic feature and miss it. I'd love it if there were a fix because I was spoiled with the automatic feature.
I have the same problem with my T621T.
