Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Matt Durrin Posted on Nov 02, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WD-52525-Code 34-Sound OK-No picture!
Lost picture, got code 34! Installed new lamp, still no picture! Checked lamp connector-ok, swapped lamps w/WD62525 lamp checked out-ok, tv goes through normal startup, but after a minute or so lamp light turns solid red! Test indicates code 34-lamp abnormality?
Robert Smith
Level 2:
Champion:
  • Expert 213 Answers
  • Posted on Nov 25, 2013
Robert Smith
Expert
Level 2:
Champion:
Answers
213
Questions
Helped
90699
Points
431
Is the fans runing at all ? if not the set will not come on at all..
A
Anonymous
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Mitsubishi WD-52525 error code 34
replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Static
where do you live? are you in maryland?
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Wd 52525 during power up the lamp red light comes on even after replacing lamp with new and good lamp?
press the menu and input/device on the set both in together and hold for 5 seconds to see if the led will blink a two didgit blink code such as 3 blinks a pause then four blinks for a 34 code. Then let me know. respond to this same post when replying.
Replaced the Lamp and get nothing, SOund works, no picture
Replace both 3300uf capacitors on the PWB thats a common cause with that model when it displays a 34 code which is lamp abnormality. if you need more information and I can psot a link where you can get the kit to repair your set with full instructions.
1helpful
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
Wd 52525 error code 34 lamp abnomality
the capictor problem is mostly for WS models
you can locate the dm model from this link
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
WD-52525 New lamp-Code 34-Lamp abnormality?
check that you did not bend you connections on the lamp housing
when you reinstalled have seem this happen
3answers
WD-52525 Lamp failed 2x in 4 months..is it the Lamp?
do you get an error code? hold the MENU and DEVICE buttons when turning on the TV and get error code
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
