Normally water collects in the bucket and the dehumidifier shuts off but this is not happening currently.
Sounds like a refrigeration problem, I am assuming the fan operates. Unplug it and let it set for about an hour. Plug it in and see if the compressor starts. If it does and you do not get water It is either low on gas or the compressor has failed. If the compressor does not start but hums it would need a new capacitor. If nothing the thermal overload has probably failed. This should get you started. Good Luck. If it is to involved they are not that expensive to replace.
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
SOURCE: not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
SOURCE: Kenmore 54501
Normal
0
When you push the power button, the blower fan comes on. In
a few minutes you should hear a second "click"--that is your
compressor starting. Do you hear that second click?
SOURCE: Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
