Hello. When you pairing a blue tooth with a samsung if required a code it would be 0000 unless is a specific code by the manufacturer.
Fix: turn off the blue tooth on settings on the phone and turn it on. Let the phone scan for devices, if it says found p that should it. When you see it on the phone press on it, the phone and Bluetooth should pair by doing so. I hope this helps. Good luck.
Pairing both devices from the Parrot Product: Select Setting / Advanced Settings / Pair with phone / Other phones * From the phone: * Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH * The phone will search for available devices * Select the Parrot Product name from the list, and enter the PIN code '1234' * The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone: * Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS * Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
you will have to pair them together again, search for devices from your phone and select parrot, then enter pin code 1234 when prompted, this should then pair again.
You can link up to 10 devices on the Parrot MKi9200.
If you link an eleventh phone, the kit displays “memory full” You then have to delete one of the linked telephones. To do this:
1. Press the knob and select Settings > Bluetooth > Linked devices.
2. Select the telephone(s) that you no longer need.
3. Select Delete
You will need to go to settings and paired devices, delete any old devices, then go to settings / advanced settings / pair with phone. this will then give you a pin code to enter. Now search from your phone for Bluetooth devices, select parrot and enter the code given.
you can find a manual at parrot.com
On your Tocca
Press menu
Bluetooth
Press the phone in the centre of the screen and it will search for other bluetooth devices
The other devices will appear when they are found
When your Parrot appears touch it and drag it into the centre
It will then connect and ask for pin
Enter the same pin on both devices and then your ready
If this doesnt help let please let me know and i will try to help you further
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices:
** From your car kit: ** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone: * Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE * The phone will search for available devices * Select CK3100 from the list of available devices and enter PIN code \"1234\" * Phone and CK3100 are now paired. Wait for auto connection
