Motorcycles Logo
A
Anonymous Posted on Apr 22, 2014
How do I charge the battery on a 1990 xlh sportster 1200
jfhinton45
Level 3:
  • Harley Davidson Master 3,506 Answers
  • Posted on Oct 18, 2014
jfhinton45
Level 3:
Answers
3506
Questions
Helped
1209071
Points
11472
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
5 Related Answers
Anonymous
  • Posted on Jul 16, 2009
SOURCE: How do I remove and replace battery on 04 1200 sportster custom?
all you need to do is remove the battery side compartment - pull from the top, and there is a hinge on the bottom. Then unscrew the negative connector -first. Then the positive. Remove the screws for the holder and its done. The new battery will have a moderate charge. You should buy a battery tender and use it to charge it. Also a battery tender will help keep the battery ready to go when you are.
Anonymous
  • 4565 Answers
  • Posted on Dec 20, 2009
SOURCE: how do i get the proper clutch ajustment on a 1989
Ok, let's start back over again. To properly adjust the clutch, you MUST do it in a particular method due to the design of the release mechanism.
First, you must "unadjust" the cable. Find the cable adjuster and "unadjust" it making the cable as short as possible, lots of freeplay in the cable.
Then, remove the clutch access cover and remove the spring and the "lockplate" that looks like a nut with a stem on it.
Turn the clutch adjusting screw counterclockwise to remove all the free play.
Now, back off on the screw 1/4 turn.
Then reinstall the "lockplate". if it doesn't want to go back in, you may have to rotate the adjusting screw clockwise just enough to get it back in. Put the spring back in and put the clutch access cover back on.
Readjust the cable so that you have a freeplay at the clutch lever of about a eighth (1/8") inch freeplay or about the thickness of a nickle.
Lock everything down and this should be correct.
I have found that sometimes you have to "tweak" the cable adjustment to get a clutch to engage exactly where a particular rider wants it to start engaging. This is a preference type thing and has to be done on a "trial and error" basis with the cable adjustment. But, you must use this method to adjust the clutch down at the engine end of the cable. Good Luck!
Anonymous
  • 4565 Answers
  • Posted on Jun 11, 2010
SOURCE: I have a 1967 Harley XLH Sportster. I rebuilt the
"Backfiring" is a pretty broad term depending on where you live. Some people refer to backfiring as popping from the exhaust while others refer to it as the engine spitting through the carburetor.
I'll assume that you're talking about popping out the exhaust pipe. If it does this after you rev the engine and it backfires on the way back down to idle, this is typical of an exhaust system sucking air. The mixture is extremely rich under these circumstances and will not ignite. But, if your exhaust system is sucking air, it combines with the fuel air mixture already there and bring it to an explosive mixture thus the backfire.
You can check you valves but I've always found that if the valves on an Ironhead are too tight, it's extremely difficult to get it started due to the low compression on that cylinder.
Check you ignition timing and points setting. Also, what kind of condition is your mechanical advance in the distributor in? I'm assuming this is an XLH model and not the magneto equipped XLCH.
What type of carburetor is on the engine? Hopefully not the original Tillotson that it came with. If it's an S&S, the low jet should be a 28 and the main jet a 66 to 70.
Anonymous
  • 4565 Answers
  • Posted on Jul 05, 2010
SOURCE: 2000 HD Sportster XLH - makes "clicking" sound trying to start
Ok, If you are absolutely sure the battery is good, there are several possibilites. If the battery is over a year old, take it to an automotive parts store and ask them if they can load test it. They'll usually do this at no charge.
If the battery is good, the first problem could be in the starter relay. Look at the end of the starter from the right side of the bike. You'll see a plate on the end that is roughly shaped like a pentagon. Just above that plate is a plug with a single wire. Unplug this wire and use either a test light or a digital volt ohm meter to check for voltage when you press the starter button. If you do NOT have voltage and the clicking you are hearing is coming from under the seat, you probably need a starter relay.
If you have 12 volts on that wire, you're problem is in the starter. Disconnect the negative cable from your battery. Now, take the three small screws out of the back of the starter that holds the pentagon shaped plate on. Underneath the plate is a plunger and a spring. Remove these parts and look at the copper contacts on either side of the solenoid and on the plunger. If they are burned badly, you need to replace them. You can get the parts through an aftermarket supplier and they are not very difficult to replace. Usually, it can be done without removing the starter. Simply replace the contacts and a new plunger comes with the parts kit. Reassemble the starter, reconnect the battery cable, and you should be ready to go.
Good Luck
Steve
Anonymous
  • 4565 Answers
  • Posted on Dec 10, 2010
SOURCE: How do I remove the negative battery cable to
You can charge the battery without removing the battery. Find the large cable that comes from the battery where it connects to the starter. Connect you positive charger clamp there. Connect the negative charger clamp to any good frame ground on the bike. You can charge you battery using this method provided you battery charger clamps are not too big.
If you can't do this, you'll have to take the seat off the bike, remove the battery hold down strap, and then move the battery outwards so you can disconnect the negative battery cable.
Good Luck
Steve
Is there an alarm system for 1997 xlh 1200 sporster
http://www.jpcycles.com/1980-harley-davidson-sportster-1000-electric-start-xlh1000/digital-guard-dawg/locks-and-alarms/exact-fit
might find one here
Fuse location 2000 1200 c
Hi, left hand side you will find a triangle cover just past the battery box. Theres your fuses man.
Kev.
1helpful
How do i track down wiring harness diagrams and schamatics for a 91 1200 sportster xl
follow this link and download everything you need to know about your bike
http://www.downloadninjas.info/service-manuals/harley-davidson-sportster-xl-xlh-service-repair-manual-for-1986-2003-models/
My 1999 Harley 1200 XLH is having electrical problems. My tach and speedo will randomly jump around, the turn signals only work every third time or so that i activate them. it appears to be random and...
Remove and clean battery cables and posts. Make sure battery is holding a good charge. Load test the battery if you have access to a load tester. Most of these types of problems are caused by a bad ground, possibly at battery or headlight or speedo housings, or at the fork trees.
Harley Davidson Sportster starter removal?
1997 HARLEY DAVIDSON SPORTSTER XLH 1200
STARTER REMOVAL
1. REMOVE LEFT SIDE COVER
2. REMOVE NEG. BATTERY CABLE FROM CRANKCASE TO PREVENT ACCIDENTAL STARTUP
3. REMOVE POSITIVE BATTERY CABLE
4. DRAIN TRANSMISSION FLUID (5/8" SOCKET)
5. REMOVE PRIMARY COVER (IF YOU'RE UNSURE OR IT'S BEEN AWHILE - PLEASE CONTACT - I CAN PROVIDE INFO)
6. REMOVE REAR EXHAUST
7. REMOVE 2 STARTER BOLTS (5/16" ALLEN)
8. REMOVE STARTER
9. REMOVE GASKET
10. SLIDE BOOT BACK AND DISCONNECT THE POSITIVE CABLE FROM BATTERY (12MM)
11. DISCONNECT STARTER SOLENOID POSITIVE LEAD TO STARTER
12. LOOSEN WIRE BAND NUTS 3/8" SOCKET
If anything you're unsure about or been awhile just comment below or reach out. The primary cover has a few quirks to get off - can go further with you if needed. All The Best, Justin Lee
17 South Industries, LLC
2answers
I have a 1979 XLH 1000 sportster and I having a charging issue.I replaced the battery and the voltage regulator and had the generator rebuilt and still it will not charge the battery.Ive checked the...
Did you charge the new battery? Did you check the new batteries electrolyte? I have seen many a new battery come off the shelf, dead! Get one of those floaty ball things and check the electrolytes in the battery, every cell, if one cell is dead, it is no good. The voltage sounds a little low but it should charge up. I don't know what size your battery is, but my old sportster had a car battery in it. Never had a problem. But never left the house without a screwdriver either.
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
