there's a website reliable-store all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge
let me know if u need more help regarding other websites
Im a routine buyer
it could be a fuel blockage or it could be that the main running jets in the carby are blocked you may have to remove the carby & strip it down & blow it out with compressed air, but check for a fuel blockage first........hope this helps......cheers.
it should be fine . remove the spark plug and crank it over . .after all the oil has spit out .replace plug and try to start . before doing any of this check the oil level , you may have to add some.......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
One idea to try. I noticed with my grind & brew that the moisture never evaporated from the inside top of the machine. Since that cannot be good over a long term, I have started leaving the top open during the day after I clean the machine in the morning. Your problem is why I started doing that. Why don't you try leaving the top open for a couple of days and see if drying the machine out doesn't cause some of that gunk to dry out?
