Archos 101 Internet Tablet Logo
A
Anonymous Posted on Apr 22, 2014
Audio not working 80 gb tabley
Audio not working archs 80 gb 8 inch tabletyboard or you tube Audio not working Sound not working
How do I run to subs 10 inch and 8 inch using majestic 1200.4 amp
A subwoofer (or sub) is a loudspeaker designed to reproduce low-pitched audio frequencies known as bass and sub-bass, lower in frequency than those which can be (optimally) generated by a woofer. The typical frequency range for a subwoofer is about 20-200 Hz for consumer products, below 100 Hz for professional live sound, and below 80 Hz in THX-certified systems
2answers
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
2answers
My Aspire one Lap top sound is not working
Hi, first check in control panel, speekers; to see you sound is set correctly. If so, under control panel go to System, hard ware then device manager and click the + to open your audio device, if there are any problem you will see a yellow ?; right click over audio and try updating your driver.
Hope this helps.
Do i need studio monitors so i can hear the sounds coming out of my mpc 4k?
you need some type of speakers either monitors that connect 1/4 inch cables left and right or you can use some speakers that hook up in the headphone jack but you are going to need an adapter to make the 1/8 inch to a 1/4
How do I play music from my lap top on this sound system?
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Does splinter cell 4 work with geforce 5200 fx
It should work if you have other recomendations Supported OS: Windows XP (only) Processor: 3 Ghz Pentium 4 or AMD Athlon 3000 (3.5 Ghz Pentium 4 or Athlon 3500 recommended) - Game optimized for dual-processor-enabled computers. RAM: 1 GB (1.5 GB recommended) Video Card: DirectX 9.0c-compliant, Shader 3.0-enabled 128 MB video card (256 MB recommended) (see supported list*) Sound Card: DirectX 9.0c-compatible (EAX recommended) ? PC audio solution containing Dolby Digital Live required for Dolby Digital audio. DirectX Version: 9.0c or higher (9.0c included on disc) DVD-ROM: 4x CD-ROM or faster Hard Drive Space: 8 GB Peripherals Supported: Mouse, keyboard Multiplay: Broadband connection with 128 kbps upstream or faster
GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Recordin audio problems (drop out)
cheak msconfig start ups eating ram that needs alot ram be nice to add 1 gb more run cc cleaner.com tool get junk out update your software form webite fl latest flash adobe shockwave and java run spyware clean up close out all other programs when u work in studio program
Top Archos Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
