Do you need to have cold water in the maker before you start
SOURCE: Bunn Coffee Maker Leaks out the bottom
The water that leaks is cold. It's leaking from the top. Unscrew two screws on the sides of the water-in grate. Lift off and put aside. The next level has 4 screws. Unscrew and put aside. Where the water enters the heating cannister, there is a clear grommet. It pulls off. Put a ring of silicone caulking on the cannister side of grommet and put it back. Press to get a good seal. Now the top part of the grommet also needs a seal. Take the second level piece and put a bead of caulk on outside of hole that goes over the grommet. Press for seal. After caulk has set is should be all-set to use. toms
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Yes, use only cold fresh water to fill coffee maker.
