SOURCE: crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
SOURCE: U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
SOURCE: Can the Sharp AR 203E Toner chip be reset?
i have sharp 203 showing code op what does that mean
