I have a svga cable (RGB connection) to connect them. at first my laptop was picking up the cable signal and would ask me what diplay i wanted. i would pick a display and it would flash on the tv screen for a sec and then disapear. the tv keeps saying it is an "invalid format" whats the problem??
SOURCE: invalid format when conected to laptop
Go into your control panel. Select display. There will be a picture showing 2 screens. Select the 2nd screen, and lower resolution to it's minimum. Apply and test. Slowly increase till you find what your happiest with. Worked for me using a ASUS laptop and LG60'plasma.
SOURCE: LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
SOURCE: How do I get LG Plasma TV 42PQ30 to work with a
well, if the cable and adapters are friendly (meaning, you are able to plug the right video connection from LT to TV), sometimes you need to tell you LT that you have a second screen to output video. To do that, there should be a display icon in your bottom-right taskbar. Double click, and you should be able to see the options to either clone, pan, or primary your second display screen. :D
SOURCE: connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
