The lens cover is stuck open and the camera will not power up. Tried two batteries and usb cable to computer but its still dead. Is there a way to do a reset.
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
I have a u770 with a broken lens. I would like to either buy yours to repair mine or I am willing to sell mine so you can repair yours. Email at (g4)(kpp)@(hotmail).(com) - remove the brackets - trying to avoid spam
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, chances
are that your batteries need to be replaced because they're just too worn to properly power the camera.
And then, of course, there's the possibility that your camera may have
a problem that requires professional repair.
I have the same problem. Have you come across a solution? It's definately my lens and not my battery. Where did you go to get the lens looked at and repaired?
Blown USB ports can happen. Most of the time, they still move power...like you can still charge devices through them, but the device won't be recognized. See if a hub will work.
I have an olympus 770 sw I used to have the same problem... the solution is after using your camera make sure the camera is dry and open the slot for the battery and clean it and do the same for the other slot somtimes youll get small debree in the cracks of your cameras cover for the battery slot thats were the water enters. I use a little bit of vaseline on the rubber pading for the battery cover to lube it out and had no problems sinse.
Not much help here, just to say that my U 795 SW came with a multi-language manual (incl English).
you can try this manual on the Olympus site at it seems to be the closest one to the model we have bought... http://www.olympus.co.uk/consumer/208_manuals.cfm?prodID=P_N2915892
The very delicate and fragile lens mechanism has been skewed by that knock.
Try Olympus for a repair price but I suspect you will be buying that new camera once you see the price
