Question about Caravell Bulova Caravelle watch
Day and date out of sync with time
Day and date are regularly out of sync with time. Usually the day & date are ahead then the time catches up.I have tried to correct it by moving the analog time ahead or back without success. And I tried it once with the digital time without success. How do you do it?
Bob from Kentucky
  • 58 Answers
Try rotating the analogue hand 12 hours ahead of the current time
Posted on Jun 22, 2009
  • David Maher
    David Maher Jun 22, 2009
SOURCE:
How do I set the day? I've configured time and home settings, but it's reading a different day, 3 days ahead, but the date is for today, I.e today is 25th May
If you cannot set the day itself then maybe it thinks it is the wrong year? unfortunately you may need to go back through the dates to get the correct year.
May 25, 2015 | Watches
The calendar skipped ahead a day and I can't get it back to where it reads the correct date. Can you help?
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
Oct 17, 2013 | Michael Kors Watches
W117-95809151012
Well, I had the same question, since i just advanced my watch past June 31 (since June has 30 days) but now my weekday is ahead by a day. So I started messing with it and found that you advance the date by advancing the time forward. But if you go backwards, the date won't change, only the day of the week... does that make since?
May 07, 2013 | Disney Watches
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Dec 03, 2007 | Watches
Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Dec 01, 2007 | Watches
Caravell Bulova Caravelle  watch Logo
341 people viewed this question
Top Caravell Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Caravell Watch Expert? Answer questions, earn points and help others
