It use to leave the time & dat on photo's. It doesn't do it anymore. I went back throught the setup and it still doesn't stamp the date & Time on the Prints. Fuji FinePix Z20fd
The date is printed on the photos using the "pict bridge" software. The date printing option is set on the computer, not the camera. If the printer has it disabled or it is a printer that doesn't support it, you won't get the date.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
The date and time (and a lot more) are stored with every picture in its metadata. Just about any photo viewing program can show you this data. If you want the date printed, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
Date and time stamp and only comes when you are shotting and your camera support this faction. When After shotting, the time stamp won't be removed from or add to your pictures by your camera.And it's sorry for that, this Fujifilm JV100 doesn't support this faction
theres no date a time stamp on the photo itself with DSLRs but the meta data is kept on file in the photo so it has recorderd the time and date. depending on what photo printing software your using you can bring up the time and date back on the photo. I have canon photo printer and using the bundled software easy photo print, it allows me to print time and date of the photo. or if you use adobe lightroom you can get the time and date back on the photo. the time and date stamp is more of a compact camera rather than DSLR.
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
While in Postcard Print mode, use the Menu button to navigate to the Date Stamp section in the Rec Menu. Select [Off], [Date] or [Date & Time] then select 'Off'. Press the Menu button again to get back to shooting mode.
I have the same camera and the only way to do this is to first,
Make sure you have set the date and time correctly on your camera.
Take a picture or,
view picture you want date & time stamped.
Press the circular 'Menu/Set' button.
Press down arrow to playback mode.
Press right arrow on 'text stamp'.
Choose whether to apply stamp to single or multiple photos.
Press 'Menu/set' to select photo to stamp.
Choose which stamps to add. Date, time, age etc..
Press 'Menu/set' again and select 'Yes' in box.
The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res.
Gillian
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
No, the date/time stamp is now part of the image. The only way to get rid of it is to Photoshop it, but 250 photos... Let me look at my manual, as mine never prints the date/time.
