All the LED lights are blinking, hold Go button and all lights are off, release and all lights flash again
SOURCE: Brother HL 5240 printer: Drum light flashing
you need to replace drum cartridge, when you buy one back ,look new one then you'll find out where is the drum.
SOURCE: Brother HL-5240 printer problem
This usually means a print job is stuck in the queue that was set to "manual feed" or to a different paper size, such as legal. Add paper to the front manual feed and press "Go". If this is the problem, the stuck document will begin printing from the manual tray.
To clear the problem without printing from the manual feed, cancel all jobs on the printer, delete any jobs out of the Windows print queue and restart the computer.
SOURCE: Brother Laser HL-5240 has a status light and toner
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
SOURCE: Strong Noise on Brother HL-5240
Make sure the end tab in the paper tray is not too tight. The tab where you set the paper length. The paper should have about 1/16 inch space and not hold the paper too tight.
SOURCE: paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
