Computers & Internet Logo
Posted on Jun 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rundll32.exe Every time I turn on my laptop, I get this mesage: rundll32.exe-Bad Image
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Jun 19, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
41202
Points
273
Hi
rundll32.exe error appears when there is the virus in your system.If you want to solve this problem you have install new antivirus.
IF you want any help just visit me--------http://techbuddies-robin.blogspot.com/2009/06/free-computer-related-technical-support.html
2answers
How to delete cookies
It depends on browser you're using. Look in settings of any browser for "Clean History"
tip
How do I fix rundll32.exe on Windows XP?
Rundll32.exe is an important process for the Windows operating system. The process rundll32.exe take the dll file and put their libraries in the system memory. Without this process, the computer should be unstable and very slow.<br /><br />The process runs from your system directory C: \ Windows \ system32. If it executes or runs from elsewhere is most likely a virus or a Trojan. You should scan your computer immediately with a virus scanner. Viruses using the name rundll32.exe are W32.Miroot.Worm. Backdoor.Lastdoor and Trojan.StartPage (among others).<br /><br /><span style="font-weight: bold;">Fix rundll32.exe</span><br /><br />If a virus, such as Netsky, destroys rundll32.exe or, if for any reason, your rundll32.exe is corrupt or is accidentally removed, you must do the following:<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Find rundll32.exe DC system</span><br /><br />Check if you find a copy of rundll32.exe in the folder C: \ Windows \ system32 \ dllcache or in C: \ Windows \ Service Pack Files \ i386. If yes, go ahead and copy rundll32.exe to the system directory C: \ Windows \ system32<br /><br />If you can not find a copy on your system, try to locate the file on your Windows installation disc. Finally, you just reinstall Windows. It would be time consuming, and you may lose all your data. So what would be the last resort.<br /><br /><span style="font-weight: bold;">First, run a system repair tool to fix rundll32.exe</span><br /><br />There are various tools on the Internet that scan, analyze and fix your computer. In addition to solving your rundll32.exe these tools to remove all registry errors, remove invalid shortcuts and duplicate files, repair DLL files, and remove the errors start-up and running.<br /><br />
on Mar 07, 2011 • Computers & Internet
2answers
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Rundll32.ex
to answer your question use the find function(right click on start button and choose explore)
in upper right panel, type in rundll32.exe and it will show you where to find it
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
In windows vista ultimate 64 bit. most of the items in my control panel will not open up. I get this message. c:\windowssystem32 undll32.exe file name or extension is to long. can you please help me. jim
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } hi
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
The rundll32.exe file operates by parsing the command line. The specified DLL is then loaded through the function LoadLibrary(). Afterwards, from the function , it gets the addresses through GetProcAddress(). The command line tail is passed when the is called. Next, the DLL is unloaded upon the return of . Finally, the rundll32.exe file exits.We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
if you have any question or any futher assistance you can get back to me on fixya for same
thanks
techbuddies
I have a pc dell xp windows and everytime i try to do something or download something it comes up rundll32.exe unknown file associated with its everytime i go to a web site that says it will fix it i...
You definitley have a virus/malware issue. This is not unusual with rundll32.exe files. rundll32.exe is a legitimate and needed file within Windows. The key is "unknown file associated" which is an indication that a new file with similar name has been inserted onto your PC.
My suggestion would be to boot into safe mode without networking and run your anti-virus software as Administrator.
3helpful
Rundll32.exe is missing
Check if you find a copy of rundll32.exe in the folder C:\windows\system32\dllcache or in C:\windows\ServicePackFiles\i386. If this is the case, go ahead and copy rundll32.exe to the system folder C:\windows\system32If you don't find a copy on your system, you can try to find the file on your windows installation disks.
Insert the windows OS CD and repair the XP, that should reload the copy of rundll32.exe.
Rundll32.exe is vulnerable to virus, so the file might have been deleted by the anti-virus you are using.
Good luck and please do rate my solution.Also post comments in case of any doubts related.
Rundll32.exe
check immediately for any virus (especially w32).your rundll32.exe files in the /windows/system32 is missing or affected.try replacing the same from some other computer.or repair the windows using the CD
Grand Canyon Tech
Grand Canyon Tech
