Samsung PN64E550 Logo
RR RR Posted on Apr 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung powers itself off and back on - Samsung PN64E550
Mike M
Level 3:
  • Samsung Master 3,349 Answers
  • Posted on Apr 21, 2014
 Mike M
Samsung Master
Level 3:
Answers
3349
Questions
0
Helped
685866
Points
16707
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
1helpful
Every few minutes my Samsung TV powers off and on by itself.
I think that it's likely to be a problem with the power supply board. I would look at it and check the capacitors on it to see if they are OK.
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
2answers
1helpful
Shutting off and on
That actually is a flaw in the Sansung phone itself, its something in the manufacturing. When getting large messages or multimedia messages the Samsung will power itself on and off. Had the same problem with Samsung.
Samsung hcm4216W turned off by itself loops.
Instead of typing model number of your TV (that located on right hand side and on the back of TV) you published here part number of your TV's remote control. LOL.
Anyway... If it is LCD/plasma panel that you talking about - than power supply have bad electrolytic capacitors that have to be replaced. You can recognize 'em by bulged/swollen tops (instead of flat tops of good capacitors).
This repair required soldering skills.
2answers
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Samsung DLP TV Powers Off by Itself
yes i have the same problem i need help
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
