In a few minutes from washing it stops and give me an LE code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
SOURCE: LE Code
Sorry I missed the LE code in the book.. Too much fun lastnight I guess.. AT any rate.. The Le fault code is a Motor overload warning. Unplug it for 2 hours and try the machine again with a test wash. if it persists you need to get a technician out for it. Hope this helps :)
SOURCE: i have an le error message
in the top console off you washer is an tech sheet with the codes on it take a look see if can get a clue there.God bless,tom
SOURCE: Maytag Fronload Washer Error Code FH
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
