Have just purchased a Casio se-c3500 cash register and thought I had successfully programmed the departments but when I press a department button the till just beeps at me and nothing happens. It prints off each department with its name (Pot of Tea etc) as I go into the department setting but doesn't seem to register it on the reg setting. Help!
SOURCE: CE-7000 Program Departmental Names and program post receipt print
Hi.
Turn key to program.
3 SUBTOTAL
100000000000
RECEIPT
SUBTOTAL
That should allow you a post receipt.
To set dept names:
2 SUBTOTAL
Department number
05
SUBTOTAL
Type new name
CASH
SUBTOTAL
If it gives an error when pressing CASH, then repeat, but press 00 button before CASH (some models need this).
SOURCE: Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3. The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
Go to a website called:
www.retrevo.com
You can download manuals there.
also you can go to Casio.com and get a manual also
SOURCE: How to program the Sharp XE-A12 cash register
here is a link to the software.
there is not enough space here to type instructions, its 90 pages long.
you will need a sd card or usb cable to connect to your puter.
http://www.sharp.ca/downloads/default2.asp
SOURCE: programming all department keys for tax
Page 34 item 2 "Tax Programming for Automatic Tax Calculation Function" in the manual. You can download the PDF version of the manual by clicking the link below:
SHARP ELECTRONIC CASH REGISTER MANUAL XE-A404
There you go... :) Please rate me for this answer.
