Question about Garden
Yamaha MT110 engine assembly
1. Are the roller bearings in the crankcase sealed or open? 2. How is the ring with the weights for the govener fitted onto the crankshaft?
    Genius:
  • 1,406 Answers
I can't speak for the governor, but I can't IMAGINE that any crankcase roller bearings would be sealed - they need all the lubrication they can get.
Posted on Jun 07, 2014
SOURCE:
Yamaha MT110 engine repair manual
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Dec 22, 2016 | Yamaha Cars & Trucks
Gas is pouring into crankcase what is causing this
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
ATV Connection
Leaking gas valve letting fuel into your engine cases
Yamaha XJ750 Owners Workshop Manual
OEM parts for Yamaha
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 03, 2014 | 1983 Yamaha XJ 650
Xj600 oil coming from exhaust
1. Piston rings worn past service specs.
2. Broken piston rings.
3. Piston pin retaining clip failure.
4. Cracked piston.
5. Broken piston ring lands.
6. Hole in the piston.
7. Valve/guide clearance worn past service specs.
8. Worn out valve seals.
9. Crushed or loose valve seal.
10. Gouges in cylinder walls.
11. Cracked cylinder or head.
12. Blown head gasket.
13. Crankcase breather blocked or hose pinched.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.snowest.com/forum/archive/index.php/t-330866.html
Need advise on an oil leak
https://biker.ee/manuals/yamaha/Yamaha_XJ600S_1992_Service_Manual.pdf
Yamaha XJ600SF Owner Manual
Apr 14, 2014 | 1990 Yamaha XJ 600
White smoke from exhaust on yz 250
1. Oil tank/pan overfilled.
2. Restricted oil return line to oil tank/pan.
3. Restricted breather operation.
4. Restricted oil filter.
5. Piston rings badly worn or broken.
6. Valve guides worn and or seals worn, crushed, missing, or have come of guide and are literally pumping oil through the valve guide.
7. O-ring damaged or missing from oil pump at crankcase junction (also results in poor engine performance). For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZ250 White Smoke Yamaha 2 Stroke
Dirt Rider Magazine
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 18, 2014 | Yamaha YZ 250 Motorcycles
Grizzly 125 transmission stopped working after chain fell off
open gearbox,maybe the gearbox brokeafter the chain fell off
Jan 15, 2014 | Yamaha Motorcycles
97 yamaha yz250 excessive oil in exhaust keeps fouling plug
Dirt Rider Magazine
YZ250 spark plug fouled after every half tank
May 25, 2012 | Yamaha YZ 250 Motorcycles
Pw80 oil coming out the exhaust
1. Engine oil over filled.
2. Piston rings worn past service specs.
3. Broken piston rings.
4. Piston pin retaining clip failure.
5. Cracked piston.
6. Broken piston ring lands.
7. Hole in the piston.
8. Valve/guide clearance worn past service specs.
9. Worn out valve seals.
10. Crushed or loose valve seal.
11. Gouges in cylinder walls.
12. Cracked cylinder or head.
13. Blown head gasket.
14. Crankcase breather blocked or hose pinched.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
HELP have oil coming out of my PW80 Exhaust
Excess oil out exhaust pipe
YAMAHA PW80 Owner Service Manual
YAMAHA PW80 Owner Manual
Apr 20, 2012 | 2004 Yamaha PW 80
I have a John Deere L120 riding mower with a 22 hp Briggs & Stratto v-twin with approx 260 hrs on it. It has been smoking & using around a 1/2 quart of oil for about the last 100 hrs. of use.Would...
IF IT WAS MINE , MIKE ,I WOULD USE A HEAVIER GRADE OF OIL-----20--60 OR THERE ABOUTS PLUS PUT A SEAL SOFTENER ADDITIVE IN AS WELL,THERE ARE ANUMBER ON THE MARKET,I USE REDEX INTHIS SITUATION. THOSE TWO THINGSWILL GIVE YOU A COUPLE OF YEARS TO THINK ABOUT IT. "YOUDOIT"
Sep 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Jun 04, 2009 | 1974 Yamaha DT 360
Garden Logo
376 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
