Make sure it's getting power, and that the "vacation" switch isn't on.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located upstream on the breaker or another outlet (not uncommon), try resetting the breaker or that other outlet.
If still no joy, check that the outlet is hot by plugging something else into it. If that item doesn't work either check the circuit breaker for that outlet by moving the lever all the way to the Off position, then back to the On position. You should hear a click like a light switch.
