Dell Dimension 4600 PC Desktop Logo
A
Anonymous Posted on Apr 20, 2014
Mouse and keyboard stop working when windows starts
See above
Abhinandan Patil
Level 3:
Master:
  • Master 589 Answers
  • Posted on Nov 06, 2015
Abhinandan  Patil
Master
Level 3:
Master:
Answers
589
Questions
Helped
124072
Points
1347
Have you checked out if they work in safe mode?
if they work in safe mood means they are working
which keyboard mouse are you using usb? ps2? or wireless?
1 Related Answer
qq hampton
  • 305 Answers
  • Posted on Apr 28, 2010
SOURCE: no keyboard windows sign in
it sounds as if your windows xp pro has not been activated. reload with the proper code or phone microsoft on number stated on activate windows.
hope this helps.
My cordless logitech mouse just stopped working??
batteries?
press connect button on transmitter and mouse
verify that the transmitter is firmly plugged in mine falls out because of the usb to ps2 adapter
make sure windows is even detecting it through device manager
does it light up at all you may have to flip the mouse upside down to see a led light
the above is in no particular order
i wish you the best of luck
Mouse doesnt work
Windows has trouble recognizing some devices. It gets it and then checks later and doesn't get it and this repeats over and over. Unplug and replug and it works, and then it starts all over again.
I have had to simply abandon using certain mice and keyboards.
Just got the bluetooth keyboard and mouse w/ no manual. how do i set it up?m/s bluetooth keyboard WBR0295 X08-92475 product ID 69418-545-205333 5-00321 and m/s bluetooth mouse p/n X08 - 87659...
Hi.
Before starting, make sure the keyboard and mouse are ON and with batteries.
Whit the PC already ON:
* The first step is to plug in the USB Bluetooth adaptor.
* Once the Bluetooth adaptor is inserted, allow Windows to install the drivers.
* Once Windows gives it the OK, the USB dongle should have a light or even a button. (If you don’t see a button the "yellow" light is the button).
* Press the USB dongle button....this will tell the dongle to start looking for a Keyboard or mouse.
* On the underside of the mouse (and keyboard) should be a a small button.
* Press the button(s) for ~5 seconds, then release.. this tells teh keyboard (or mouse) to look for a dongle.
This should show a connection between the dongle and the keyboard (or mouse).
Or
With the PC Off:
* Just connect the dongle
* Do the button sequence as described above, unit the dongle light goes “solid” again.
* Start the PC and keyboard and mouse should work perfectly.
Cheers,
Ed
3helpful
My mouse just stopped working. I have a cordless
I would start by pressing the Connect button on the bottom of the mouse, then the Connect button on the bottom of the mouse receiver connected to your computer.
If that doesn't work, try replacing the batteries, then going through the Connect method mentioned above.
Mini mouse GE 98763 stop working and I can't start
If you are using window you can download the software at:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Choose system and select wireless optical mouse
Mouse not working at all and need help with the BIOS & how to make my mouse work
Left click start. Left click control panel. In Vista find Hardware and Sound and left click on mouse. You should get a window which allows you to set mouse functions. In XL Left click start. Left click control panel. A window should open listing various computer systems. Left click on mouse. You should get a window which allows you to set mouse functions. If you don't see mouse symbol or word, make sure the mouse software is installed. This should work. You can check on the mouse software by going to Device Manager and checking Input Devices. To do this go to Control Panel as directed above. Left click start. Left click Hardware and Sound. Find Device Manager and left click. Then, find Input Devices.
Keyboard problem
If they both stopped working at the same then it's probably a problem with the motherboard and not the keyboard or mouse per say.
Regardless we've got to try something, right?
I'd start with removing the keyboard and mouse from the device manager, then restart the computer (without the external mouse and keyboard)
If that doesn't work try updating the bios.
If the model you listed above is correct then the latest version for your laptop is located here:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4844&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
Let me know what happens.
Best of luck!
3answers
Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
maybe it is full of dust on those buttons. Try cleaning it with a duster of mini-brush because it interrupts the function.
Mouse not working
Mouse not being detected in Windows 9x, ME, 2000, XP, or Vista. If the other mouse works in this computer attempt to use the mouse not working in another computer.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
Autoexec.bat and config.sys help and instructions If the mouse drivers are not loaded properly you will not have the .... line is the name of the CD-ROM driver on the particular system we are working on.
Good Luck/Please dont for get to Vote.Thank You
1helpful
Microsoft wireless multimedia keyboard 1.0A
I suppose you should reset the keyboard and mouse and maybe the access point itself. Try find small buttons on each devise and press them AT THE TIME. You may need somebody's help. Those buttos can by hidden under mouse and keyboard and should be on the top of the access point. This depend on the model, so please reffer to a manual.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
