Why has the circulation flow decreased
Your pump pushes "Unfiltered" water thru the Filter. Your filter then "Cleans / Filters" all of the microscopic particles of dirt out of the water. This will eventually clog your filter as the pressure will then obviously climb. Basically, doing the job it was intended to do! As this occurs the water flow will be reduced and at times, dramatically! The fix: clean the cartridges, backwash your sand or D.E. Filter.
Another possibility is the flow is restricted due to another type of clog: Plugged pump impeller, clogged & dirty skimmer or pump baskets, etc.
Or low water level. Sucking air with water.
