I don't understand the symbols. i need to cool. don't know if its a freon issue or a symbol issue. thanks
SOURCE: Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
SOURCE: i have a carrier minisplit ac and need a remote
If you bought the extended warranty, you have coverage to 2011. You fall in Carrier LAOs' jurisdiction. The HQ is in Miami and they can get what you need asap
SOURCE: I have a carrier wall heater with a remote, and I
Hi, Sally378, I may need to get any model numbers you may have for the remote or the unit to solve this. If this remote has batteries you may want to change them to see if this takes care of it. If not, send me the model numbers from both the remote and unit itself.
Sincerely,
Shastalaker7
