Question about Pride Celebrity X 4-Wheel Electric Scooter
Mitsubishi shogun Unable to lift double seat forward to make more luggage space, single seat will lift when you pull on side lever but not double, how do i resolve the problem
How do I remove the seat to remove the battery?
pull the lever and lift, or unlock the lock under front of seat and tilt back seat, or pull levers and tilt pull forward lift off, or flip lever in back and slide out, or undo front or back and slide out the batteries.
Make/Model PLEASE.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Nov 30, 2015 | Health & Beauty
My jet 3 ultra seems to pull one way when going in forward like it pulls one way more than the other.
I suspect that your seat is out of alignment.
On the control side of you unit there is a lever which allows you to alter the position of the seat so if you lift this up and forward you should be able to 'square your seat' in a for and aft position.
Be sure to return the lever or else it will be quite unstable.
Joe
Jul 22, 2014 | Jet 3 Ultra Power Chair
After adjusting the driver'sseat to the max length-- to look for an item, I am unable to get the seats postion to unlock and allow me to pull the seat foreward... help
Thanks for choosing FixYa and welcome to the site. Have you checked to make sure there is nothing down in the rail? Have you tried to apply pressure forward, while pushing the button forward or is it a lever? Does the other seat work if it is powerwed? Have you checked the fuse?
Apr 06, 2011 | 2001 Mitsubishi Diamante
I have a old mercury villager ...i want to replace the middle row seat with last row seat ...is it posible...?
The middle row seat slides forward to the middle position (and several other positions as well.)
Owners manual explains how to slide rear seat foreard.
Remove middle row seats. Lift handle under 3rd row seat cushion on passenger side. Raise seat cushion up until it locks up. Then lift the lever on the passenger side of seat and pull seat forward until it locks in place.
if you don't have owner manual, go to motorcraft.com, pro center, tech info, owner manual.
join our group for free help.
please rate too. Thanks.
http://groups.yahoo.com/group/villagerquest/
Jan 24, 2011 | Mercury Villager Cars & Trucks
2006 Ford Explorer: Back seat won't fold flat to create flat cargo area. It folds down but not flush.
Okay so im just going to start from the seat being upright in a normal riding position.
1. You need to fold the head rests first. Pull the black tab under both headrests. They should spring into a folded position.
2. pull the side seat lever (on the door side of the seat). This will fold the top/back support down to an angle.
3. There is one more lever on the backside of this seat. Its in plain sight on the angled portion of your seat. Lift the big plastic lever.
4. While keeping the handle lifted, grasp the back of the seat and pull it torwards the front of the car. The seat should come unlocked and roll forward and down more towards the floor. If you have a bunch of junk on the floor, it obviously wont work. clear the path and the seat will fold completely flat.
Also, your drivers seat and front passenger seat cannot be all the way back, they need to come forward some in order for the second row seats' head rests to clear and fold flat.
Oct 02, 2010 | 2006 Ford Explorer
Is there a rear seat release on a 94 accord
I believe this procedure applies to your 94 Accord:
With your hands, press down on the seat cushion where it meets the seat back. Locate the retaining bolt(s). Some models retain the seat with one bolt in the center; others use two, evenly spaced left and right.
Remove the retaining bolt(s).
Lift the back (toward the rear of the car) of the seat bottom upwards while rotating it toward the front of the car.
Disconnect the hooks at the front edge (during the rolling motion) of the seat and remove the seat bottom.
Remove the carpet (in the luggage compartment) from the rear of the seat backs.
Remove the seat back mounting bolts from the luggage compartment side.
Lift out the seat back.
If the rear side bolsters or pads are to be removed, remove the lower mounting bolt, then push upward to free the hooks.
Hope this helps you.
Dec 21, 2009 | 1994 Honda Accord
Remove seat from second row in Honda Mini Van 2007
on the passenger side feel under the seat and there is a lever that pulls toward you as you stand at the sliding door.
First, raise the armrest, then lower the back all the way forward. Then remove the headrest sit it out of the way and while pulling the lever under the seat towards you, lift up the seat from the back so it tilts forward. When it is standing on its "nose" lift first one side shifting it either forward or backwards to clear the rod on which it is hooked. Do the same with the other side of the seat and then lift it out. Installation is the reverse of removal.
The other seat is much the same, though sometimes the lever is a little different but in the same place.
Good luck,
bob
Jun 07, 2009 | 2006 Honda Odyssey
Hai i would like to know how to fold the back car seat to increase cargo space in hyundai santa fe 2003
The rear seats have a pull strap located between the bottom cushion and the backrest of the rear seats used to disengage a lock to lift up the bottom cushion. The pull straps will only stick out an inch or so, or they might have fallen down between the seats and then you wont see them. Before you can lower the backrest of the rear seats, the bottom cushions have to be lifted up and forward out of the way so that the backrest may lie down flat. If your pull straps are not visible between the bottom cushion and the backrest, you may have to stick your hand between the cushions and feel for the straps. Once you find the straps, pull upward on the while lifting on the bottom cushion where the pull strap is located and the seat should tilt forward. Once you have manged to do this, the lever for the backrest is located on the top of the backrest. Just slide the lever and tilt the backrest to the desired position.
Apr 13, 2009 | 2003 Hyundai Santa Fe
Pride Celebrity X 4-Wheel Electric Scooter  Logo
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
