Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
j
jim root Posted on Apr 21, 2014
Chevy s10 will not start. turns over fires and then dies
Says open in the fuel volume regulator control circuit. what is the problem and where can I find the salutation?
Alex Hernandez
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Apr 21, 2014
Alex Hernandez
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1474
Points
Turn the key to on /run position. Remove gas cap and listen for a humming noise. If nothing is heard then the likelihood is the fuel pump is bad. But before removing the fuel tank, check all the relays and fuses for fuel. If that all checks out as good, then check the entire ignition system (cap, rotor, wires, and coil.
1 Related Answer
cwradio73
  • 1162 Answers
  • Posted on Mar 30, 2014
SOURCE: the injectors wont fire on my 1998 chevy s10 zr2
Is it happening on all cylinders? Or just one? Have you removed the injector an inspected it. I have never heard of all going bad at once. It would be a good idea to look for open fuses. The main connector is connected properly, each one has good connection.have you changed something lately?
I need a diagram to troubleshoot a p0001 code on 2010 chevy equinox
https://repairpal.com/obd-ii-code-p0001-fuel-volume-regulator-control-circuit-open
Mercedes 2004 ML350 Fuel Volume Rugulator Control Circuit /open code on PO 001.....car cuts out whilst driving and refuses to start until it cools down a bit...
code p 0001 refers to fuel volume regulator control---circuit open===causes ---wiring---regulator control solenoid
the indications are that the solenoid is opening circuit ( breaking the circuit ) and stops working when it gets hot internally
replacing that unit most likely will be the fix for your problem
What would cause you to lose fuel pressure while driving.
Chevrolet S-10 Questions - Fuel System Loses Pressure ...
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusJul 28, 2012 - Fuel System Loses Pressure - I have a 2003 Chevy S-10 Pick Up with the 4 ... car a few times, what essentially you are doing is priming the fuel pressure. ... A dirty fuel filter will not cause the lines to lose pressure after the engine is shut off. ... I have a 98 s10 2.2 liter and it was driving fine all day then when ...
Chevrolet S-10 Questions - My 2001 S10 has a hard starting ...
CarGurusSep 16, 2012 - My 2001 S10 has a hard starting problem if the truck sits between 1 ... Vacuum leak, have you checked fuel pressure while it sits? ... Would the spider alsocause a misfire at low rpms? .... at an idle, or squeaking while driving and it gets faster as you go? ..... 1994 Chevrolet S-10 2 Dr STD Standard Cab LB.
Chevy S-10 Won't Start - Repalced Fuel Pump and Pressure ...
www.cartruckinfo.com/chevy-s10-wont-start.html
Chevrolet S-10 pickup won't run and has no fire unless I jumper the fuel pump relay. ... Once the truck starts and is running you can remove the jumper to the fuel pump ... Iwould get the fuel pressure checked to start with, because that's where the ... 93 gmc 4.3l FI runs but dies out loss of power after 5 mins of running then ...
Stalling S10: I Have a 1994 Chevy S10 2.2l It Stalls After 35 ...
Code p0001
P0001 it refers to fuel volume regulator control circuit/open
Have a 98 chevy s10 that will start but will not run
check the solenoid next to fuel pressure regulator on fuel rail,and the wiring to it ,or the bad relay at fuse box in engine compartment
What does P001 fuel volume regulator control circuit open means
basically it means that the regulator solenoid is unserviceable ( broken wire or burnt internally) and needs to be replaced.
Fuel volume regulator control circuit open
p0300 random engine mis-fire
fuel pressure regulator is on fuel rail, has 1 vaccum hose
2answers
Well i have a 1983 chevy s10 2.8 and its been broke down for awhile i just put a full tank in before i was having this problem the thing is it started just fine from the gas station and it was fine for two...
sometimes if a fuel pressure regulator goes bad , you will be able to smell fuel fumes under hood. a leaking pressure regulator will cause---hard starting, poor fuel economy, stalling, check engine light, gas smell under hood. also check all fuel lines under hood.
2answers
2000 S10 no start
I'd use a gage and check proper fuel pressure, key on engine off, 60--66 psi with spider fuel system.
Engine cranking did you visually check for spark at the spark plugs? Engine cranking is there a fuel injector pulse?https://s8.postimg.org/50arofh11/fuel_pump.jpg
Click on the link for fuel pump relay, you can check the fuse. At the fuel pump, gray wire is voltage, black is ground.
Top Ipcw Office Equipment & Supplies Experts
Arnie Burke
Arnie Burke
Polo
Polo
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
