Question about LG LDF8812 Stainless Steel Built-in Dishwasher
Lg dishwasher soap dispenser does not open during wash cycle
  • LG Master
  • 3,247 Answers
It is usually due to a lid spring problem or the solenoid operating the lid is faulty. In any case you need to replace the whole dispenser assembly. It looks like this (item K001) in this assembly chart.
http://www.appliancepartspros.com/section-4-parts-for-lg-ldf8812st-asteeus.html
To save hassles it might be worth switching to the dishwasher tablets instead of the powder. You simply drop the tablet in cutlery basket. A good brand like Finish should do you wonders. Might seem a bit expensive per wash but you extend the life of the dishwasher due to its cleaning efficiency.
Posted on Apr 23, 2014
SOURCE:
ra_j13
  • 11 Answers
SOURCE: LG DISHWASHER
This is a common fault if your drain hose or the drain pipework after it is blocked by tissues or fluff etc remove the drain hose from the vertical drain pipe or u-bend connection and check that all are free of obstructions. Also a lot of machines have a filter located at the bottom of the machine either behind a flap at the front or located near the pump at (usually) the back of the machine underneath. This can be got at by either removing the back panel if there is one or tilting the machine forward to access it from underneath chock the drum with wood to avoid drum suspension damage or re- attach the drum bolts which were removed when the machine was delivered if you still have them. The pump will have a rubber hose attached before it and the pump is connected to the machine end of the drain hose, often the rubber hose is large bore and incorporates a hard plastic filter designed to trap buttons coins etc before entering the pump and damaging the impeller blades, remove any debris.
In essence you are making sure the the whole drainage route from the drum to the final drain point is clear and free flowing.
Posted on Jul 14, 2008
rickzilla
  • 706 Answers
SOURCE: LG Dishwasher model LD-1415M. Detergent
First off, clean the detergent dispenser as best you can using white vinegar.. make sure you get any and all left over soap deposits off the cup and edges of it then,... try cycling the dishwasher without any dishes on the hottest setting and after it is about ten minutes into the cycle.. pause it and add two cups of white vinegar inside the dishwasher.. That should remove most , if not all left over deposits from the system. See if that frees up the dispenser .. Make sure the drain filter is has been cleaned thoroughly prior to running this process.. Hope this helps...
Posted on Sep 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: water leaking from dishwasher lg model lds5811ww
The drain line is clean. Have you checked to make sure the the rest of the drain is clear all the way down to the main drain?. Also check the pump to make sure that it is working properly, it might be pumping water in, but it may not be wanting to pump the water out
Posted on Feb 11, 2009
  • 423 Answers
SOURCE: Soap block not releasing while washing
I urge you to only use Electrosol or Cascade powder with your (or any) dishwasher. Most ultra-cheap powder will not clean effectivly. If the dispenser does not open with the powder inside, a service call is the next step.
If you reply, please tell me the Make and model of your dishwasher.Good Luck!
Posted on Mar 31, 2009
  • 64 Answers
SOURCE: LG dishwasher is making loud grinding sounds
debris in pump. unplug and disassemble pump. clean out and reassemble
Posted on Aug 26, 2009
The soap dispenser door will not open during the washing cycle. What could be my problem? I have a Lg dishwasher model #ldf7561st
If you don't want to disassemble the dispenser to replace a part, you can replace the entire dispenser. Additionally, if the dispenser isn't working and the entire dispenser is worn out, replace the dispenser.
Sep 26, 2015 | LG Dishwashers
My soap dispenser is not opening during the wash cycle,so the there is no soap being dispensed during the wash. This has always worked before, then one day it just stopped opening. What's the problem?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Oct 26, 2010 | Frigidaire Professional Series 24 in....
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
748 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
