Question edited for a lot mode clarity, and add maker and model name. It is a VL for 'Volusia', not an LV1500.
Question moved from Power Motorcycles.
The Tip Over Sensor is under the seat. From the Service Manual, the last link
When the motorcycle tips over, the tip-over sensor sends a signal to the ECM. Then, this signal cuts OFF current supplied to the fuel pump, fuel injectors and ignition coils.
Sensor G on Page 30.
Page 70 shows a picture of it
TO SENSOR INSPECTION The tip-over sensor is located under the front seat. (Page 70)
https://www.google.com/search?q=suzuki+vl1500+intruder+tip+over+sensor+location
tip-over sensor reset - M109 Rider Forums
m109riders.com
https://www.m109riders.com > ... > M109R Shop Talk
Usually all you do is sit the bike back up, then make sure the k-switch is on (run position), then cycle the ignition to off-on-off again....
Missing: vl1500 ' Show results with:
vl1500
Help needed with 1500 Intruder
Motorcycle Forum
https://www.motorcycleforum.com > threads > help-ne...
Jun 7, 2021 - The repair manual shows that there is a tip over switch under the seat. I have a fuel filter exactly where the switch is shown in the book. I am ...
REsetting Tip Over Sensor
Adventure Rider
https://www.advrider.com > threads > resetting-tip...
Aug 30, 2006 - According to the Service Manual, the tip over sensor is to deliver a 3.7 - 4.4 volt signal to the ECU, or the bike will not start.
Missing: vl1500 intruder
VL1500 Service Manual
Crowitis
http://www.crowitis.com > images
During deceleration, the fuel injection time. (volume) is decreased. SIGNAL. DESCRIPTION. TIP-OVER SENSOR SIGNAL. (FUEL SHUT-OFF). When the motorcycle tips over ...
181 pages
