SOURCE: Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
SOURCE: the power on my laptop won't stay on
The jack or AC power pin can be fixed yourself if you're up to it. The part is usually under $10. I've done three (2 Fujitsu' and a Sony. Take your time when you take it apart and take pictures of the disassembly. They will com in very handy when you start to put it all back together again. When you get it fixed invest in a proper cable retention device so the AC power pin doesn't get damaged again. This short Chris Pirillo Video talks about CRDs on laptops.
SOURCE: SONY DCR-TRV20
Yes, Power supply/ charger can be one reason. You can get ACL-15A from following Sony link.
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
SOURCE: Elmo TT-02u, Random freezes
The problem is a set bad capacitor that must be replaced by the factory. The units are very critical on the exact amperage that the power supply delivers. We have hundreds of tto2 and a few have had this problem. Elmo is aware of the problem and your warranty should cover the problem.
