Question about Broderbund Printmaster Silver 12.0
Uninstalling printmaster silver 12
How do I unistall printmaster silver 12 I have tried to go into add remove programs and it won't let me do it
  • Susan Hall May 11, 2010
    What is the message it gives you when you try to uninstall? Do you have the original installation cds?
    Problem Solver:
  • 6 Answers
U can't remove ur print master? i had encounterd this prob before
so try to install again ur print master to overwrite all files. coz u unistall it improper thats why u can.t remove it..
try to install again and after that u can now remove it into add/remove progam thx for posting!!
Posted on Jun 27, 2009
    Problem Solver:
  • 4 Answers
First I would uninstall the program again.
Then go to start, search and look for PMUSERS.dat and delete it.
Restart your computer
It is also a good thing to temporaily turn off any antivirus software before installing also. Many programs like this Broderbund product do not install completely with the antivirus software on.
Then reinstall the program and it should run ok.
Hope this helps.
Sorry about the first post...my cat stepped on the keyboard!
SOURCE:
Ould like to uninstall broderbund dfrom windows XP
If you have tried using the "Add/Remove" or the uninstaller from the software itself and cannot uninstall the program. Reinstall the program again and unistall it.
If it is not sucessfull, then
Try using the System Tools "System Restore" utility in XP to restore your Operating System to the point before you install the software.
Hope it helps.
Oct 20, 2010 | Broderbund PrintMaster Platinum 15 Full...
I have printmaster 15 on my computer but would like to uninstall it, i have no use for it. i dont have the disks for 15, only the disks for 17. how can i remove this.
go to start > control panel > add/remove software it will take a bit to generate the list, but once populated, created, just findany software you dont want including printmaster and click unistall. This will remove all the files off your computer.
Feb 25, 2010 | Broderbund PrintMaster Platinum 15 Full...
I have printmaster 12 on my computer and want to uninstall it. I do not have the install CD anymore, can you help with that?
Go to start, programs, control panel, and then to the uninstall/install programs wizard. I can't describe what you will see exactly without knowing the version and setup of your operating system.
If for some reason you cannot see Printmaster listed in programs when you try to unistall, go to start and then to your print master program entry.
Often, programs have an uninstall built in. If it doesn't, you can leave comments for me during the ratings process and I will answer any questions you many have.
Please leave as much info on what you saw/encountered as possible so I can help effectively. Happy new year.
Dec 29, 2009 | Broderbund Printmaster Silver 12.0
I recently had my computer serviced for a major virus attack. System operates on Windows XP. I now cannot open PrintMaster Platinum 12. I get a message "cannot determine configuration." Additionally, I...
May have to uninstall it first, then reinstall it.
Click START button, lower left corner
then click Control panel
then click on add or remove programs
*see if your product is listed(may be under BRODERBUND or other publisher name)
If it IS listed, uninstall it
Or sometimes the UNINSTALL is included in the CD options:
Insert the cd into the drive
go to my computer
find the cd drive
right-click the drive
select "explore"
Look for an Uninstall program
Hope this helps!
hansola
Nov 06, 2009 | Broderbund PrintMaster Platinum 15 Full...
Bad install of printmaster version 11
Try reinstalling the software, when finished restart your computer then again try to remove in add/remove programs.
Hope this helps
Apr 17, 2009 | Broderbund PrintMaster Gold 11 for PC
PRINTMASTER12
You need the CD installer for it to work because some of files needed already lost. You need to install & uninstall to completely delete it in your computer
Feb 27, 2009 | Broderbund Printmaster Silver 12.0
I recently uninstalled Printmaster Silver 12 (temporarily needed all the hard drive space I could get), and now I am trying to reinstall. The install process gets to the registration phase, gives the...
Most programs like this leave behind "junk" files or folders with some information in them.
Try uninstalling it again, then go to the C:\ drive and look for any folders that it might have left behind.
Then go to Start do a search for PMUSERS.dat and delete it.
Jan 16, 2009 | Broderbund Printmaster Silver 12.0
How do I uninstall printmaster silver 12
the question was regarding PrintMaster Silver 12, although it was posted in the PrintMaster Platinum 16 forum.
Anyway, Broderbund has the instructions on their web site
http://support.broderbund.com/fix.asp?isid=30284&print=0&prog=1294819732
Oct 18, 2008 | Broderbund PrintMaster Platinum 16
Printmaster 12
CLEAN INSTALL needed here.
Try un-installing again, but this time after the un-install, shut down completely for at least 30 seconds, and then restart.
This releases "Locked files" for deletion
Then do a search for 'all files and folders' - search for both Broderbund and then Printmaster, with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those files found.
You should do this search and delete whenever you un-install any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Printmaster
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling.
Dec 05, 2007 | Broderbund Printmaster Silver 12.0
Broderbund Printmaster Silver 12.0 Logo
303 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
