There was a lot of coffee grounds ll around inside an I have vacuumed these out.
You cant put the drawer back in its place because the grup is not in the correct possition.To bring the grup to the right possition you need to press the switch that the drawer presses when it is puted correct inside.Look at the drawer and you will see at the back side a knob, see where it enters at the machine (that is the switch).Press the switch with something plastic and the grup will move and stop to the right possition.Now you can put the drawer back on.
SOURCE: Saeco Easy
I think I have the solution. The "thwok, thwok, thwok" noise is a solenoid opening and then slamming the trap door that dispenses the coffee. Mine had a similar problem.
Upon removing the top, I found that the solenoid, and further that the mount where it attaches to the plastic frame was broken. Basically, the little plastic fin that should hold the lower flange of the solenoid was sheared off. That left the solenoid free to move, and made it impossible to complete the action to move the dispenser trap door.
It looked like there was no easy way to replace that part of the plastic mount, so I epoxied and zip-tied the solenoid into place. It seemed to do the trick. I doubt it will last forever.
-tony
SOURCE: dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
SOURCE: SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
SOURCE: grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
