Horrible smell of stale water coming from inside washine machine
This is usually caused by mostly using low temperature washes. The detergent manufacurers don't tell you, but low temperatures don't kill the bacteria present on most clothes, so they breed and and multiply in nice warm moist washing mashines. The cure is to do a "maintenance wash" every so often, which is the hottest wash the machine can do, and this will kill the bacteria. Also adding washing soda to this wash will help to freshen it up.
Hi
The smell usually comes
when the washer is unable to drain water completely, you can run your washer at
its hottest temperature setting with 1 cup of vinegar inside the unit. After
this take off the bottom front panel and clean it completely, also clean the
drain hose and drain pump filter, the smell should disappear after doing all
this. Hope this helps...please post back for further assistance.
Daniel
