if motor reving and going where = torque converter
if stuck in third and reverse only fail safe mode tripped in the tranny control unit 4L60E RepairGuide Assembly other checks stick shift bushes faulty neutral safety switch on side of tranny check linkages into the box move easily rare but parking pawl stuck inside the box ...
Sounds like the backup light switch is stuck. It is normally installed in the side of the transmission case and is activated by the transmission going into reverse. They can get gummed up over time and fail to release when coming out of reverse.
Does the gear selector show that is in reverse? Does the transmission have gear selector solenoids on the transmission? If so, may be a bad reverse select solenoid. Do the 'backup' lights come on when reverse is selected?
