LED Battery Indicator
When charging:
Red - X-mini KAI Capsule Speaker is charging
Blue - X-mini KAI Capsule Speaker is fully charged
When in use:
Blue - X-mini KAI Capsule Speaker is turned on
Blue (dim) - X-mini KAI Capsule Speaker battery low
During playback through bluetooth, users will be alerted if
charging is required by a three-beep indication
If this is not right you will have to email them on [email protected]
or if is in Warranty, get it repaired by the Seller.
Where the bluetooth options on your phone will depend on your phone.
So to put the speaker into Bluetooth pairing more slide the power switch to the right hand side. If the speaker has power then a blue light to the right should light up.
Once this is done you will need to find the Bluetooth devices option on your phone. This will be located somewhere under settings - connectivity.
When you locate the device in bluetooth devices, select it then select pair.
If you can't find the bluetooth options on your phone, comment on this answer with the phone name and model and I will see if I can find out for you.
There is no more any official download. For a little fee of 5$ (to buy me some cigarettes) I will send you a working copy of my installation. It works with Win7 (32 and 64 bit) Now in 2019: it works with win7, win8, win8.1 and win10 !! (tested) [email protected]
battery aur charger nikalne ke baad, 2 min tak power button dabay rakho .. phir battery, charger lagao , contact manufactrur and get BIOS update software ,, install it
IF YOU WANT TO CONNECT SAMSUNG CORBY PRO(GTB-5310) TO YOUR PC OR LAPTOP FOR INTERNET THAN DO THE FOLLOWING STEP-
1. INSTALL dotnetfx35-vista_X86 ,GIVEN IN CD NO.2 GIVEN WITH MO. SET (I HV WIN VISTA OS)
2. NOW INSTALL KAIES GIVEN IN CD NO.1 BUT HERE YOU HV TO BE CARE
FUL THAT YOU SELECT CUSTOM SETTING ,NOT DEFAULT SETTING AS INERNET
OPTION IS NOT GIVEN IN DEFAULT SETTING (HERE MOST PEOPLE DO MISTAKE)
3.restart your comp
4.connet your phone to USB,open Kaies,right most down corner of the home page of Kaies hv option for internet
5. select it and follow instr like connection name and Country
FOLLOWING STEP-
3.restart your computer 4.connet your phone to USB,open Kaies,right most down corner of the
5. select it and follow instruction, like connection name and Country
Find anyone who uses XP. Install SuperGoo there. Copy the the whole Folder where Super-Goo is installed to a stick. Copy this folder to your computer (programm files (x86)). Run the program - it works.
DEAR FRNDS IF YOU WANT TO CONNECT SAMSUNG CORBY PRO(GTB-5310) TO YOUR PC OR LAPTOP FOR INTERNET THAN DO THE FOLLOWING STEP- 1. INSTALL dotnetfx35-vista_X86 ,GIVEN IN CD NO.2 GIVEN WITH MO. SET (I HV WIN VISTA OS)
2. NOW INSTALL KAIES GIVEN IN CD NO.1 BUT HERE YOU HV TO BE CARE FUL THAT YOU SELECT CUSTOM SETTING ,NOT DEFAULT SETTING AS INERNET OPTION IS NOT GIVEN IN DEFAULT SETTING (HERE MOST PEOPLE DO MISTAKE)
3.restart your comp 4.connet your phone to USB,open Kaies,right most down corner of the home page of Kaies hv option for internet
first do you have a "short" in the Controller, try another one and see if it does, also try cleaning the game disk with something like "windex", also try "checking any add on memory, you could have a "Glitch", in either of these, but try them one by one, start with the easy ones first, let me know if I can be of more help, also try disabling the the "vibration", and see if it still does it, god bless and happy 4th
Mobile is do not warking kais 130 windowing problem,,,,please help me,,,,,01774648353////for bangladish,,,or,,, mobile phone number,,, 01774398131,,,,,please help me
