Hitachi 42V710 42" Rear Projection HDTV Logo
J
Jesse Posted on Apr 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Mitsubishi WD-73727 dlp TV, picture went out and lamp indicator started flashing red then orange. i replaced the lamp but the problem persits, any help?
Picture went out and got a new lamp, installed new lamp but still get the flashing red then orange lamp indicator, I've tried the system reset button on the front of the tv but no luck. I then removed inspected and reinstalled the new lamp and still no luck. Any ideas to what the problem might be?
Steve LaHuis
Level 2:
  • Expert 418 Answers
  • Posted on May 09, 2014
Steve LaHuis
Expert
Level 2:
Answers
418
Questions
0
Helped
106426
Points
974
Lamp light blinking yellow means lamp door not installed.
Lamp light solid red and TV shut off is lamp error (did not light.)
1 Related Answer
Anonymous
  • 65 Answers
  • Posted on Aug 09, 2009
SOURCE: Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
1helpful
2answers
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
5738 status light blinks red 5 times then orange 7 times
if it is a 7 then u must replace.
SOURCE: i am a mechanic
4helpful
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
1helpful
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
1helpful
2answers
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
