Watch Computer on Mitshubishi WS-55819. Help me please.
Look on the back of the set and see if you have a VGA connection available. On many of the HD series they do. If id does it should also have a audio in via rca jacks or a 3.5mm stereo jack. If the set does not have a VGA input on it , look on the Laptop and see if it does have S-Video out. If it does, you can probably use it in the S-Video in on the TV and run the Audio out from the Laptop to the audio in of the S-Video Input you are using. I would use the VGA Jack if available. Be aware that if it does and you use it it will only work in low 800x600 at 60Hz.
Hope this helps,
Skyassoc
