to use or running Notebook in a battery, simply unplug the battery charger ( power chord) and your battery should be fully charged.
by the way, if ou having the problem of a laptop shutting off when you unplug the
charger when your battery is fully charged, there is nothing wrong with the laptop, battery, or computer, it is a
power management setting. What you need to do is:
- Go to display properties
- select the screen saver ta and click the "power" button
- In the power schemes tab there iss a drop down window, click it and select "Portable/Laptop" (it is a power switching utility that quickly switches between AC and
Battery when the power cable/charger is plugged in or unplugged while
the laptop is on)
hope this help a little, ask me if you need more assisst.
regards
