I just had a Sears Kenmore 7.02 cu ft freezer installed in my home.I thought that it would shut off after 4 or 5 hours of operation but. its been running 20 straight hours and has not shut off yet.I called Sears and they told me that this was quite normal and to give it 24 hour to reach its freezing level. I manually shut it off and it came back on after 5 min.Any suggestions?
Take it Back
Testimonial: "I agree that the Sears Tech was full of Sh/t"
sears tec full of ****.the data plate will tell you how many oz. and type it will be r-134a. and no its not normal.may be a freon level causing extended run time are you sure the compressor is running 20 hrs? either way. you should get it taken care of. have you gotten your electric bill yet? you'll be surprised
the freezer shut off after 20 hours of continual operation.Came back on an hour later and ran again for 20 hours is this normal? the sears tech said that it is normal for this model to run a lot.Is it because they do not use freon anymore.
Has it cooled off at all?
