In the PLAY/EDIT mode the touch screen buttons/functions are no longer working, making it impossible to play the tape. Help!
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at a reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Thank you for the hint. I have to get a battery for the remote to check your suggestion.
must be the flex cable, since the remote control does operate the machine.
I am having the same issue with touchscreen buttons not working in my DCR-HC20. I tried the manual reset (remove AC+Batt, switch to ON for 15 secs, etc.) a few times but I doubt it reset the camcorder as the time and date are still accurate. I'm hoping to fix the touchscreen by a simple reset before taking repairing/replacing the camcorder.
Any idea how to proceed?
If the flex wire that other people mention needs to be replaced, can it be done by me? I'm handy and technical.
Thanks!
Play it with its remote. Seems flexible wire between lcd board and camcorder main board is bad so touch buttons not working.
